Jake Raby 2276 with EFI
1 Attachment(s)
For Sale 2276 fuel injected type 4 engine.... 173 bhp
Engine spec Engine Case- 022 type 4 Bearings -Original VW Klolbenschmidt Crankshaft-78.4- Balanced and Counterweighted Connecting rods-H beam 5.400 length Camshaft- Web Cam ,custom grind Lifters L N Engineering Ceramic Cylinder and piston assemblies 96 mm cast iron with Hypereuctectic pistons 96 mm Cylinder heads -New castings full stage II port and polish with hand shaped chambers with balanced chamber volumes Pushrods -Manton Chronoly ,cut to length Rocker arms VW forged units, 1.3:1 ratio solid spacers Valves-stainless steel made by Marnel Valve adjusters - 911 swivel feet Oil pump- Modified Type 1-/Shadeck 30 mm gears blueprinted Ignition-Mallory Unilite distributor Ignition cable etc- Bosch Cooloing system DTM Stage IV Flywheel- 210 mm with Raby Aircooled Technology conversion flywheel Pressure plate- Sachs new Clutch Disk- new Sachs Rabys Fully programmable EFI with dual twin throttle bodies call or email please 07803 971 147 UK |
You might throw out a asking price just to keep people clear on what this is. This is a best-of-the-best, top of the line engine. There is usually a waiting list to have one done.
Also, is it still in the states? or have you already got it home? Just trying to help you get the right phone calls. Jeff- |
| All times are GMT -4. The time now is 13:39. |
