-   -   rack and pinion for 74sb (https://www.germanlook.net/forums/showthread.php?t=10282)
vwbao November 13th 2009 17:51
hiI have a question about installing a rack and pinion to non rack and pinion super beetle, what else do I need? I have the rack and pinion with mounts from sb 1975, do I nee to change my steering column/copler or other else?
thank you.
derek
Joel November 18th 2009 07:37
the steering shaft with universals is a different lenght so you will need it as well
ive got it all sitting here waiting to go in mine, just been putting if off as the frame head needs clearancing a bit under the wheel well
Steve C November 18th 2009 17:35
1 Attachment(s)
This is what the chassis looks like underneath. The chassis clearancing would be the biggest headache, maybe weld in a 1/2 tube. I've only done it on a 1302 and it needed a lot of work, maybe the later bugs don't need as much.
vwbao November 26th 2009 00:02
hi, do you think with the 74 model will only need the frame head cut and none on the spare tire well?
vwbao November 26th 2009 00:15
is this the 75 model or the pre 75?thanks
Steve C November 26th 2009 00:25
The photos is from a 75 I wrecked, it had the rack & pinion that Joel has now.
vwbao November 26th 2009 00:40
do you have a picture of the frame heat of the 75?
Steve C November 26th 2009 03:27
I will did it out from where its stored at the side of garage and take some photos.
vwbao November 26th 2009 14:49
Thanks mate!
