Cayman 987 /987c discs??
Hey Guys
Does anyone know if the rear disc for 987/987C Cayman is the same as the original Boxter rear disc?? (20 or 21mm wide) or is it 24mm? And also the diameter?? It would nice to use this over the 944N/A discs ? Cheers Dean |
No, not the same. Only the very early 2,5 ltr Boxster with model nr. 986 had the thinner rear disks in 20.5mm. All other rear disks are 24mm ;)
Thanks man. That clears that up.
Appreciate the info;) |
| All times are GMT -4. The time now is 13:08. |
