1303 German Look Wannabe
I've been reading on here for years and thought i'd post a link to my resto - on VZI..
http://www.volkszone.com/VZi/showthread.php?t=514502 http://i208.photobucket.com/albums/b...6.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...1.jpg~original http://i208.photobucket.com/albums/b...8.jpg~original http://i208.photobucket.com/albums/b...0.jpg~original http://i208.photobucket.com/albums/b...9.jpg~original http://i208.photobucket.com/albums/b...8.jpg~original some taster pics! I've pretty much finished the body now -couple of cosmetic bits to weld up before I can commence modifications :D Porsche 901 gearbox loosely fitted whilst awaiting my NOS 1800 Type 4 motor. I'm planning on injection and have several T4 injection systems along with a knackered turbo i'm going to use for pipework mock up!! Hoping to get the chassis rust repaired shortly - there isn't much to do - then maybe I can get the new suspension and brakes started. |
Yikes! You're taking on some tough duties. Obviously, you have some mad skills. Well done so far. Performance will be the easy part.
You are off to a very good start so far! Keep the updates coming!
WOW. Thats a lot of cutting, fitting and welding.
Thought i'd show some of the earlier pics!
Here are some of the earlier pics showing some of the work i've had to do:
http://i208.photobucket.com/albums/b...8.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...3.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...7.jpg~original http://i208.photobucket.com/albums/b...1.jpg~original http://i208.photobucket.com/albums/b...4.jpg~original |
http://i208.photobucket.com/albums/b...1.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...0.jpg~original http://i208.photobucket.com/albums/b...5.jpg~original http://i208.photobucket.com/albums/b...0.jpg~original http://i208.photobucket.com/albums/b...6.jpg~original Just a taster!!! |
:eek: That is alot of metal repair! :eek:
I've got to do some of that to the lower corners on rear window... not looking forward to it. You're doing a graet job! Keep it up! |
Jayzus!!! You wouldn't by chance work at a dairy that makes swiss cheese wud ya? Nice work patching her up!
Jason |
Repaired the floor pan rear brace
I measured this up at 2mm, then looked at a bit I had left over from a previous floor pan I had fitted - generally have never used this part - and found it to be 1mm thick!!
So moral is don't use this bit off pattern pans!! I made a piece up in the end from 2mm sheet. http://i208.photobucket.com/albums/b...0.jpg~original http://i208.photobucket.com/albums/b...1.jpg~original http://i208.photobucket.com/albums/b...2.jpg~original http://i208.photobucket.com/albums/b...3.jpg~original http://i208.photobucket.com/albums/b...4.jpg~original http://i208.photobucket.com/albums/b...6.jpg~original http://i208.photobucket.com/albums/b...5.jpg~original So all repaired and awaiting the pan repair that I've made but not fitted :D |
Wow!! nice metal work
Well done on the rust repair! Its such a accomplishment if the body is solid again as in your first pics.
I know exactly what it takes as you may have seen in my thread on the first page ;-) Keep the pace and get her painted and driving asap since that gives extra motivation, then you can upgrade later as much as you like :-) |
Hi Wally,
Thanks, i've looked intently at your work and it is an inspiration to me for my bug! If mine turns out half as good as yours I will be very happy :D I have a turbo on the bench lol!! |
http://i208.photobucket.com/albums/b...6.jpg~original Not much to report.... maybe get more done next weekend. |
The Plan....
Hi All,
Here is my latest thoughts on the bug... http://i208.photobucket.com/albums/b...S.jpg~original ATS rims for that classic German Look motor Opinions invited..... |
| All times are GMT -4. The time now is 09:15. |
