-   -   Spark Plugs (https://www.germanlook.net/forums/showthread.php?t=11510)
SilverBullet July 25th 2012 05:18
Spark Plugs
Which spark plugs do you use? Especially in hi-po engines.
Different head range affects engine performance?
Thanks.
Turbonutta July 27th 2012 10:39
i use an nkg bps 7 its a heat range or two higher than stock as mine is a turbo aircooled
SilverBullet July 29th 2012 20:15
Thanks for the reply, as my friend"s 2165 had problems when used stock plugs, he changed to ngk 7, no problems. Its does affect does it!
