-   -   single piston 1985/944 front calipers (https://www.germanlook.net/forums/showthread.php?t=11700)
effvee October 6th 2013 23:47
Me again, in my storage I've collected enough 944 rotors calipers and rear parking brake rotors for three bugs, because I have three bugs.
Two of which I noted that the front calipers bolt pattern could be adapted to accept, the front calipers on the rears. I thought that the front may be to much breaking, on all fours;I tried to use the rears on all four but the bolt pattern was to wide.
Once I got the rear bolted,I noted that I would have to either mill down my pads; or mill the rotors. I chose to mill down the rotors. So, is there a thinner rotor for the rear 1985/944? Any thin rotors from later Porsche?
