Type IV cams
Hi everyone, I'm not sure where I read that Nitriding cams were not good for tool steel lifters. Can anyone speak to this?
I bought my cam from Pauter, I have heard of cam builder cams failing. At present I'm going through a tare down of a friends 1835 type one engine because of highly possible cam failure. Way back when I had the ideal of having the Pauter cam heat treated, and did. I was supposed to run this cam and engine on a 356 dual spring lifters, but have heard since that the 356 stock lifters may not hold up, wow. I was looking at the issue of trying to get some 356 lifters again. In a old post on pelican parts, I posted the 356 lifter need. One member said to have the lifters magnaflux and x rayed and reheatreated, will this be I good fix? Or just have the lifter bores re-bushed for the type one lifters. Since I already have the bushing installed into my case, I hope it won't be to hard to machine the bushing to accept the type one tool steel lifers. So, back to my question, is there a problem in Nitriding the cam? I had City Steel heat treat my cam to I believe 61 Rockwell, and have since bought the tool steel lifters. Lastly, who sells high quality 356 style lifters, ones that I can run dual springs. |
Nitriding the cam will not affect tool steel lifters. If that happened,they were not tool steel lifters ;) All cast iron cams are nitrided and/or heat treated,unless they would wear too quickly.
| All times are GMT -4. The time now is 06:42. |
