-   -   Ever seen this front sway bar setup? (https://www.germanlook.net/forums/showthread.php?t=158)
Oliver Knuf August 16th 2002 04:34
1 Attachment(s)
Just to take a look on techniques from Germany, this setup is from my father's shop, done to get exact stabilizing at the point, where it's most needed, also possible as adjustable race bar, more done to get enough place for a big front oil cooler in front of the axle.
Take a look!
bren August 16th 2002 05:49
neat!! :D i like that.. ive had problems getting my bugpack HD swaybar to stay well mounted on the trailing arms.. theres no way your bar will work loose! how much would something like that cost to buy? or is it a one off custom job?
vujade August 16th 2002 06:34
very interesting Oliver. I can appreciate anything that has been well engineered. So, in addition to making more room for a front mounted oil cooler, does it work better then a stock setup?
Sandeep August 16th 2002 14:36
Awesome
Cool Oliver.....
I will make that mod to my ride this winter !
Thanks for the great pic !
Angelo Amato August 16th 2002 20:08
I've seen this setup in the metal ! so clever you wonder why nobodys thought of it before !! :D
hot66 August 18th 2002 03:44
nice set up.
What diameter is the sway bar? Are you selling this as a kit?
Oliver Knuf August 19th 2002 06:41
We carry them in my fathers shop, price is high, as the unibal-fittings are too expensive, I'm searching for a new supplier. At the mo it's 240,00 Euros for a complete kit, every kit machined for each customer by hand. The diameter is 15mm and it works better than anything else tested (12mm standard, 181 15mm, Eibach 17mm, 19mm Sway-a-way in both directions mounted), great for race applications with more drilled holes to adjust the side length of the bar!
DORIGTT August 19th 2002 18:34
How do I order one for my car?
What information can you give me on ordering one for my car?
I've got a balljoint front end on my VW.
What about the rear of the I.R.S. cars? Do you have a new solution for that end as well? Or would we be better off using the 944 rear anti-roll bar setup?
Thanks in advance.
Kevin J Hale
Oliver Knuf August 21st 2002 04:26
Just send a mail to order@powertuningparts.de...
The rear is easy, as you can only use the 944 parts, but use the original mounts from the torsion bar housing, too. Cut them off and weld them in the same position to your beetle housings!
I have a mixed conversion with a 19mm sway-a-way bar on my car.
Philippe August 23rd 2002 02:30
I have the same problem! I don't really like how my bugpack sway mounts on my trailing arms-- it isn't secure. This one looks like it takes care of the problem. Though I don't know that I can justify the $240 over the $50 bugpack investment...
trevorbrady August 23rd 2002 03:50
I've got the same anti-roll bar on my bug, with bolt-up clamps. I can't see a problem with it (well, it's been a while since I looked!). What do you see as being the problem with yours bren?
Maybe I should take a close look at mine...
bren August 23rd 2002 07:42
problem with mine (bugpack 3/4" urethane mounts, stainless bolt-up clamps) is that every couple of months or so it works its way loose! you can literally move it by hand! it was better when i ran drilled out stock rubber mounts but i split two of those and had to revert to the urethanes it came with.. i cant bring myself to drill some more rubber ones, it was a real bear the first time!!
im happy with the way mine works, i certainly dont think its TOO stiff like most people seem to reckon they are, but im just not satisfied with the way it mounts.. its a shame no-one makes real rubber mounts to suit the 3/4" bars instead of the urethanes... i HATE urethane.... i think its half the problem.....
trevorbrady August 23rd 2002 09:12
jeez, guess I'd better take a look at mine. It's been on 2 months now and I haven't checked them. I have the exact same setup, urethane bushes, bolt up clamps. I don't think it's too stiff either. I much prefer it to the stock VW one. The car feels much more surefooted with it on...
tab69vw August 23rd 2002 14:58
Does anyone know what the front trailing arms are made of, are they steel or casted? Can they be welded w/o any problems?
Murdock September 1st 2002 18:54
Re: ...
Any way you could take a picture of your setup? I have a 74 Ghia that I'm trying to fix up to the German Look, and now I'm at the suspension point. I'm fairly new to all this and want to do it right the first time! ( is there such a thing?)
Thanks alot!
