Painting 944 rear hubs
I am sandblasting and spraying all my 944 rear suspension parts prior to fitting - is there any issue with me doing this to the early rear hubs? I will protect the threads with tape, but didn't know if there was an issue with the surface where the disc attaches to the hub.
On a related note - any one know what thread and size the screws to hold the disc to the hub are? Neither of my hubs had the screws - I know this is no issue as the wheel and wheel nuts hold them on but would like to have all parts present. Thanks Paul |
it will be ok as long as you don't lay on an inch of paint :D
I'm getting all my parts powdercoated, & I'm just going to make sure, after 50 miles of driving to recheck all the torque settings once all the mating surfaces have settled together |
If you use spray paint get VHT as it's the best for this type of application.
| All times are GMT -4. The time now is 02:52. |
