-   -   nut size (https://www.germanlook.net/forums/showthread.php?t=1768)
Aurumen March 19th 2003 22:23
nut size
anyone know the size and thread of the nut that goes on the bottom stud mounting for shocks on a ball joint front end? I lost one of the nuts when i put on my new koni shocks and don't wanna have to buy 25 different nuts at the store to find the right one...thanks
Nick
Steve C March 20th 2003 06:52
Im pretty sure that they are M10, not sure about the pitch, they should be the same as the nuts that bolt the motor in and a host of other VW uses, why not take your remaining nut to your local nut & bolt shop or VW shop and buy one.
Steve C
Aurumen March 20th 2003 09:19
I was trying to avoid having to take the other half apart because i already had that side fitted with my new 25mm front sway bar....i'll go buy a couple of M10s and give it a whirl. Thanks
Nick
