-   -   axle too short (https://www.germanlook.net/forums/showthread.php?t=1819)
beachball6 March 26th 2003 22:44
axle too short
my csp drums came today and the axle is too short to go all the way through the drum. the axle nut gets on about 2 threads thats it. is it ok to cut the drum part that is too long it doesnt look like it will hurt the integrety. wat should i do?
shawn
kdanie March 29th 2003 01:10
Sounds like you have drums for a '68 that uses a slightly longer axle and wider shoes. Having that part machined down some is common but I don't know for sure how much you can take off.
ken
flat March 29th 2003 19:34
68 and later cars have longer splines. To use the 68+ drums on earlier cars, you have to trim 0.600" - 0.625 off the snout of the drum. Good Luck
beachball6 March 30th 2003 17:31
thanx for the exact measurments
shawn
