-   -   BAS exhaust question (https://www.germanlook.net/forums/showthread.php?t=2000)
Supa Ninja April 24th 2003 20:32
Any of you guys that is running a full BAS exhuast system , I am wandering which hole in the apron does the tip come out? I got myself another rear apron and I want to fill the other hole but I don't have the exhuast yet. Thanks in advance.
Nick
Alex April 24th 2003 20:42
Normally it is the left one (driver side) when you stand in front of the rear apron.....but the tip is actually not attached to the muffler so that you can fit it to your car if I am not mistaken.
The T1 exhaust I had from BAS was that way. The part from the muffler to the rear apron is actually 2 parts that you will have to get welded.
zen April 24th 2003 22:36
i just sent sandeep some pics of the pieces to post in the gallery. the silencer system has the tip separate so you can fit as needed.
zen April 24th 2003 22:39
1 Attachment(s)
actually, here is a pic for you...
Supa Ninja April 25th 2003 10:32
That clears that, thanks Alex and Zen.
Nick
