-   -   front shocks - koni's, spax or bilsteins? (https://www.germanlook.net/forums/showthread.php?t=2529)
hot66 July 11th 2003 04:12
thinking about buying some front shocks to suit a beam front suspension, slightly lowered & dropped spindles.
koni's
spax
bilsteins
lightning bug July 11th 2003 04:26
I voted Koni b/c I've had good luck with them. Bilsteins adjust themselves though and are bombproof. Either one, you'll be fine. Spax... Yuk.
MattKab July 11th 2003 15:38
Others
http://www.koni-na.com/cars.html
hot66 July 11th 2003 17:07
matt, you running Koni reds then? I'm very interested in peoples opinions of the shocks they are using
Alex July 11th 2003 22:43
I voted Koni. The Bilsteins are as good or even better shocks....but they have a problem:
They actually push up the car and it will not look as low anymore.
When you compress a Bilstein the shock comes back up. The Koni does not.
So when the car is not moving you will find that it is not as low as when you are driving. My friend had the problem in the 90s with his fronts and I had the same problem with my New Beetle.
petevw July 12th 2003 05:05
how about KYB's?
MattKab July 12th 2003 09:19
Yellows mate, front and back. 'Can't fault them, except tweaking the front is a bit of a ball-ache.
This video clip is good:
http://www.koni-na.com/images/int_subbutshockvidov.gif
Matt
hot66 July 14th 2003 11:03
koni reds it is then :D
zen July 16th 2003 21:05
i need to make this same call soon. where are you buying hot66?
hot66 July 17th 2003 18:04
prob a place in the UK near manchester, can't remember the name though
