944 bolt spacing
I found a 944 with the rear bearing covers still there, and I need to know what the center to center caliper bolt dimension is. 4cm?
944 Caliper bolt spacing
Rear single pot calipers and all 4-pot calipers axial mounted are 95mm. Early 944 front calipers (single pot) are 76mm. MG |
94mm ;)
Hey what's a mm between friends :D
MG |
...about 19mm error on a keyboard :D
All 944's are 94mm on the rear calipers. :D
| All times are GMT -4. The time now is 04:38. |
