-   -   wrong rear hub? (https://www.germanlook.net/forums/showthread.php?t=2697)
SuperRSi August 4th 2003 12:23
wrong rear hub?
1 Attachment(s)
My late model 944T trailing arms were cobbled together from several sources. I bought the "trailing arms" on-line and when they arrived all they really consisted of was the bare trailing arm. Soooo, I took them to a local wrecking yard/ Porsche shop and they assembled the set. Now the problem is when I put the rear rotor on the hub it does not even begin to cover the parking brake pads. So I guess my question is wrong hubs or wrong rotors?
Randy
Alex August 4th 2003 12:31
Well...it is either or!
Those hubs are from the late style al arms. You need to get disks for those. Your track increase will be a lot bigger with those.
YOu might have early style disks and this is why they do not cover the e-brake shoes.
I would try to source some early style hubs. They sit flat on the al trailing arm and do not come out on a cone like this one in the pic.
SuperRSi August 4th 2003 12:46
Wow the answer took several minutes...
I will take them off and head out to find the flat hubs.
Thanks again,
Randy
