-   -   Heads (https://www.germanlook.net/forums/showthread.php?t=2791)
zynnad August 20th 2003 14:58
Heads
I am looking into building a type IV 2.0 ltr engine for my super beetle and I have some questions.....
1. Can a type 1 head be used on a type IV?
2. What size intake and exhaust do Ineed for a daily driver that should be good on fuel and power, so I can rattle the "other" imports once in a while?
3. Is a dual weber 34 ICT a good set up for this?:confused:
kdanie August 20th 2003 23:08
Type 1 heads do not fit. 42mm intake and 36mm exhaust (2.0L 914 stock sizes) are a good size for decent HP. Dual 34mm carbs is not enough, you need 40mm dells or webers with 34mm venturi in each hole so that's twice as much carb as the ICT carbs. The ICT cabs are too small to make real power. Properly tuned 40 dells can get just as good mileage and make much more power.
ken
jrinlv August 21st 2003 00:25
I thought I saw it done somewhere, with 1/2 + 1/2 pushrod tubes from TI and TIV, I'm positive that I saw that pic. with TI heads on a TIV case. I'll look for it......... JR
Shad Laws August 21st 2003 10:18
Hello-
Well, SCAT heads use the 1/2+1/2 pushrod tubes.
Big problems:
T4 bore spacing = 124mm.
T1 bore spacing = 112mm.
T4 stud pattern = 96mm x 78mm (with one offset an extra 4mm)
T1 stud pattern = 81mm x 76mm
I can just aout guarantee that you did _not_ see a T1 head bolted up to a T4 :-). You likely saw the SCAT split ports...
Take care,
zynnad August 21st 2003 10:25
Thank You
All this info is awesome!! This is one great forum. Thanks people for all your info!
Dan
jrinlv August 21st 2003 20:57
That makes sence now that you say it was the spilt heads, I looked all day............. Sorry to mislead you JR
yetibone August 23rd 2003 12:47
One question I have regarding Type IV heads has to do with fitting larger valves to a pair of Bus heads. I understand that 2.0 914 heads drop valve seats with catastrophic results sometimes, and if the Bus heads are not metalurgicly worthy of such an upgrade, then I don't want to ruin my engine while finding out.
Is it safe to install 42x36 or larger valves in '75-'79 2.0 Bus heads, or is it more cost-effective to find genuine 914 1.8 or 2.0 heads rework them?
Yetibone
yetibone September 1st 2003 10:14
Anybody?
Yetibone
Massive Type IV September 1st 2003 10:52
The 2.0 914 heads are worse for cracking......not dropped seats. The problems with dropped seats are vanished if you look to a good TIV head rebuilder.
yetibone September 1st 2003 11:20
Thanks Jake. Unless I can find some 1.8 litre heads to use, I think I will call Headflowmasters to install 42x36 valves in my 2.0 Bus heads.
Yetibone
