-   -   type 1 or 4 better with turbo (https://www.germanlook.net/forums/showthread.php?t=2815)
kenfyoozed August 23rd 2003 17:54
ok so im beating a dead horse, buch please help.
im looking for longivity and reliablity, but want to add a turbo. is one better than the other?
for a type 1 i was thinking of 1776 or 1915 .
for type 4 i was looking for anything stock.
ill be putting it into a bug. im thinking a mildly over stock type 4 with a turbo will be the best route, but wouldnt this also be more expensive.
which would last longer, given both are cared for the same way?
neil
TitoRay August 23rd 2003 23:27
I believe a T4 would last longer of course but is FAR more difficult from what I've gathered.
More expensive, harder to do, parts availability, etc.
I guess it also depends on your resources.
On the other hand, 1776 cc, or a 1915 cc turbocharged T1 could be quite reliable I imagine. As long as you stay sane with the boost and what not.
dgluyas August 24th 2003 06:19
Turbo Type 1
I have a freind who is running a turbo 1916cc Type 1.The turbo is from a nissan 200sx. It is run at 16 PSI and it s generating 150kilowatts of power on the dyno. I have been in the car and truely it is awesome ! It runs 11.85 for the 1/4 mile !
kdanie August 24th 2003 13:38
Type 1 and type 4 engines are about equal in price to build IF you use quality parts. Type 1 can be cheaper if you use cheap parts. I don't know of any commercially available turbo exhaust headers for a type 4, there are a couple for the type 1.
ken
