-   -   Urethane IRS pivots (https://www.germanlook.net/forums/showthread.php?t=3342)
Pillow November 20th 2003 18:38
Urethane IRS pivots
Simple question here I hope. :)
I am mounting IRS arms (from a 944) and installed the Energy Suspension red urethane bushings for the IRS pivots. Now how do the washers work in this setup?
I assume one on each side, but again unsure.
Panelfantastic November 20th 2003 19:06
Be sure and post when you figure it out. I've been eyeballin' my bushings and wondering also. Someday, hopefully soon, I will have arms to put them in.
What are you doing for lube against squeaks?
Pillow November 20th 2003 20:19
I am just using the lube that came with them... If they squeek then so be it... Just put on straight cut cam gears and a stinger :) LOL
boygenius November 20th 2003 20:23
I was told by my local VW shop that the two washers go on the outside of the bushing.
Panelfantastic November 20th 2003 21:33
My wife says the stinger on our oval makes it look like it has wood:eek: !
craazy Cooter November 20th 2003 23:02
uhhh huh huh he said wood
Pillow November 20th 2003 23:27
>I was told by my local VW shop that the two washers go on the outside of the bushing.<
I have heard that as well... So again I am stumped!
Amazing how simple this question is and I do not really have a clue! Honestly I am beating myself over the head on it... I feel like a novice rub :(
boygenius November 20th 2003 23:40
I checked my well worn VW beetle manual. It shows one washer on each side of the bushing. I would assume that it would be the same for the porsche suspension. Hope this helps...;)
hybrid_john November 21st 2003 00:33
why dont you buy a used Porsche 944 manual and see what it say: you should be able to find one on ebay for $5-$30 and have it at your door step in a couple days....at least it would solve the problem
hope this helps:)
zen November 21st 2003 09:13
i've been meaning to look into this same thing myself. just haven't gotten around to it. will look over pelican parts for a parts diagram.
Pillow November 21st 2003 12:13
The answer is... Both!
The Haynes specifies 2 washers on the outside per stock VW IRS.
The Bus Boys instructions state that one washer per side is required for thier special mounts. Which is the way I will go on this.
Do not quote me on this... But I hope to have some control arms in today :)
boygenius November 21st 2003 20:09
My haynes manual shows one on each side but doesn't even mention them in the text.:silly:
Deathbug74 November 22nd 2003 07:53
heh..my ex just complained that the stinger was too loud :rolleyes: i think it goes good with the lines of the car...it matches the angle of the new beetle antenna on the roof.
zen January 11th 2004 17:30
my suspension had been pulled off by the PO, but it had both washers inboard. looks like i am putting them back in with one on each side. :confused:
Panelfantastic January 11th 2004 19:18
Me too Zen. Haynes or not, this is the way that makes sense. :cool:
