are my 911 seats heated?/
hi ive just purchased some porsche 911 leather electric seats
i think there 80's ones. theres just two buttons on each seat with arrows facing up and down plus u can manualy recline the seat by lever heres a pic does any1 know wether there heated [IMG]http://muchos.co.uk/members/ja66/102_0217.JPG[/IMG] |
Welcome to the forums. About your seats I'm not certain if they are heated. You can check www.pelicanparts.com they have a technical section for 911's and a year by year options list. Hope this helps:D
cheers
still cant find no info :doh: |
hi
they are the height controls under the seat will be two motors if you conect 12 v to the pin block were a connector normally goes then press the button the seat should raise or lower . i have a set in black in my celler at the moment. |
my 911 seats are motorized to, they came out of a 85 carerra. they have 4 pins on the plug (two for ground and two for power). it sounds like yours are only motorized aswell, not heated... but could be wrong.
so whats the other switch for
if ive one with an up and down arrow what does the second button do |
hi
front up-down rear up-down ! |
back part of the seat?
any recomended sites where i can get info
the one above is useless cheers ja:) |
hi
one switch makes the front part of the seat base go up and down the other makes the rear part of the seat base go up and down so you can have your seat at a rearward tilt if you got long legs mayby or if your a bit of a short arse like me raked forward . |
i get it now:o
takes us britts a while to catch on:silly: |
How well do they fit in your car? Do you have to squeeze them into the car. Are they any wider than the stock VW seats.:)
hi
yea agree with the british thing it takes me ages sometimes:silly: as to how these seats fit well! i dont know im recovering the centre part of the sqab and the backrest red to match my car(if my sowing skills are up to it) so there in my celler at the moment!!! i can tell you that i have seen picies in various magazines with porsch seats fitted in kaefers and karmanns but i have not seen them fitted in a squareback they should fit. measure twice cut once and all that. |
fit luurveley:D :D :toilet:
Cool. Thanks a bunch.:D :D :D
| All times are GMT -4. The time now is 10:22. |
