Hi Alex!
Hi Alex, just wanted to know what size rims and offset you using for the rear with your 944t trailing arms and are your fenders widened? Doing the same but I can't fit my 16' boxster 7x16 et 40 at the rear with alu. arms as it sticks out bout 20-30mm with my widened 40mm fenders!:)
8.5 ET50 at the rear with 40mm wider fenders. Fits perfectly.
Which al arms do you have? The early style or late style? Mine are early style. Alex |
Hi Alex, its the early arms, its 86T, was wondering why it couldnot fit! Also using MBT rear 993 C2 brakes. Could it be the brake conversion?:(
I am not sure.
Alex |
| All times are GMT -4. The time now is 19:23. |
