-   -   Porsche wheel in a early Supa (https://www.germanlook.net/forums/showthread.php?t=3560)
Supa Ninja December 26th 2003 18:57
In '74 VW changed the steering shaft from the large splined to the narrow splined. Now what does all this mean, you ask? Simple if you want a Porsche steering wheel in your Supa and it's a '73 or earlier then you have two options, 1) drill out the rivets in the hubs of both a Porsche wheel and a stock '73 earlier wheel and swap hubs(when I did it the wheel was never centered properly), or 2) install a '74 1303's steering shaft, and then simply bolt a Porsche, or '74 on steering wheel on and your done. The horn and blinker turn off will work normal as well. I was going to write a tech article but the procedure is very simple.
You'll have to use a '74 only steering shaft because in '75 VW went to rack and pinnion.
SNN
NO_H2O December 26th 2003 19:49
Yep, I swapped the shaft in my car and then went with another wheel so I swapped it back to the original shaft. So i have a 74 shaft for a Super(ior) if anyone needs one.
Superman December 26th 2003 22:42
The early Porsche 911, up to around 1985 has the same spline as the early Super and the later Super has the same spline size as the water-cooled VW. Also, take note that the change over in the 1974 shaft was done mid year production.
MattKab December 27th 2003 07:50
Is the early '03 upper shaft the same as that of an '02?
Matt
NO_H2O December 27th 2003 10:24
73 should be.
jhelgesen December 27th 2003 16:40
Dave, I'd take that steering shaft off you hands if you still have it.
NO_H2O December 27th 2003 16:53
I got it. It's yours for the shipping John. Email me you Add.
Your box went out with all the others.
