Spindle Shafts
undefined DO THE DRUM BRAKE SPINDLES AND THE DISC BRAKE SPINDLE HAVE THE SAME SHAFT? (ARE THE BEARINGS THE SAME?)
THANKS |
Yes, and also BJ and super bearings and bearing-spacing is the same. Back in the day putting super drums on a BJ front end was a popular option (super drums and wheel cylinders are bigger than BJ).
SO USISNG A SET OF CLASSIC & SPEED PARTS (CPS) VENTED ROTORS ON MY DRUM SPINDLES SHOULD BE NO PROBLEM RIGHT? :) |
Yes, but only if you don't need to bolt on a caliper. The only way you can convert is to get DISC spindles, which have mounting ears for the calipers.
I HAVE 944 CALIPARS AND BRAKETS. JUST CONFIRMING AN EASIER/ CHEAPER WAY OF INSTALLING THE ROTORS. THANKS AGAIN :D |
Ok not to take this post on a tangent, but I'm looking at doing the 944 conversion on the front of my 1302. Changing to the 1303 front suspension is not a option as I already have three bolt Maxx struts. I have two options it would appear.
1) Use my stock drum three bolt spindles, have a little machining to the face of the spindle to clear the 944 hub and get a caliper mount machined that will bolt to two of the holes for the backing plate. Also I'll need to figure out the bearings and grease seals. 2)Get ahold of some spindles from a disc braked 1302(european) and most likely have to have a caliper mount machined to fit the 944 calipers. Also probally have to have the face machined and of course adapter bearings and grease seals. (The bearings and grease seals just need the width and OD of the 944 stuff and the ID of the VW stuff) I will be starting on this project soon. So if any of you guys have insite into this matter, it would be much apreciated. Also what brand of bearings is the best? Once again sorry for biting off this thread but I believe that it is all relivent. Thanks Nick |
frank's vw werks will make the bearing spacers for about $88 or assemble the setup incuding the machining for about $280 to 350. or you can use rotors from cps (reqires no hub) and just make a caliper bracket and nessesary adj to attach them. |
Thanks Steven I hadn't been to Micheal Ghia's site in a while, so I'll check that out. I still want to run the 944 stuff because I already got the parts and I don't think the csp rotors are 11 inches.
Nick |
| All times are GMT -4. The time now is 23:56. |
