-   -   for 1303 of the 72 (https://www.germanlook.net/forums/showthread.php?t=3789)
barbe February 3rd 2004 10:13
for 1303 of the 72
Good morning, I am Spanish in case anybody does not know it. In the forum I have participated in some post but I need aid. I have a 1303 of the 72, the one that has 3 screws in shock absorber of the front. My question is that pieces I need porsche to be able to make a good machine? It is for doing it of once well. That it leaves from 911 or 926 or 928, to be able to connect it? Thanks
barbe February 7th 2004 15:33
:bawling: :bawling: :bawling: :bawling:
yetibone February 7th 2004 17:19
You can find the information on the suspensions forum. Use the search function, and type in "944 brake conversion" or "944 brakes" and you should find a large amount of information covering that topic.
Simply put, you would need...
'74 1303 front lower control arms and struts
'85 or earlier 944 spindles/hubs/rotors/bearings/calipers
Kerscher balljoints
Yetibone
barbe February 8th 2004 05:02
Merci yetibone for all :D
