Porsche code ?
What offset is a 928-361-616-00 rim, phone dial? Thanks for the info.
Isn't the offset usually stamped on the rim somewhere? JR |
It is usually displayed as ET40 or ET50 ect...
Any help here, I need to know, the sooner the better. I thought they would be 23 or 52, not 40 or 50? Any help though would be great..Thanks JR
Boy sorry if you where just using that as an example........
JR, you working on some other rims also?
they should have an et52.3 or et23 for phone dials. |
I have the same wheels 16x7 phone dials
i did some measureing yesterday on my wheels 6 5/16" backspacing or 160mm and if my measurements were good offset is 2.4375" or about 62mm |
they are 928 rims look in a reference for 928 wheel et for the same width and diameter wheel they did not chage them that much
if thats a help i have some 7" x 16" 928 gullidecks (flat face with a slot cut out) the ET is 65 search 928 rims on the net.. :confused: |
The only listing that I can find for that part number has a "-85" under remarks. This may or may not be the ett of the wheel.
Try a search on the web? Good luck, Dave |
| All times are GMT -4. The time now is 09:37. |
