-   -   Vdubcustoms hubs (https://www.germanlook.net/forums/showthread.php?t=4109)
lowemp April 4th 2004 22:54
Vdubcustoms hubs
has anyone used vdubcustoms to produce front hubs for a porsche brake conversion? I have a 1969 Squareback which I am planning to fit 944 NA brakes.The rear appears straightforward. The front hubs appear to cost in the $500 range. Would I be farther ahead to have the 944 hubs modified, or to go with 4 pot brakes if I am going to spend this kind of change for the hubs? Any thoughts are apreciated.
boygenius April 4th 2004 23:24
Check out there 944-S front brakes. Those are mine and I should have them tomorrow (Monday). You can pick up the 944 front rotors, calipers, and hubs pretty cheap on ebay. I got my front brake components for less than $100 and the rebuild kits are only about $22 for the front calipers. If you want a customers opinion of the product I will hopefully know tomorrow.
Brendan...
