-   -   MC Options (https://www.germanlook.net/forums/showthread.php?t=4214)
volkdent April 25th 2004 00:56
MC Options
What are the various options for MC that will bolt to the stock locations?
With or without power assist.
Thanks guys! I'd be banging my head a lot more if it wasn't for this site.
boygenius April 25th 2004 01:00
I bought a 1987 911 master cylinder and it bolts right onto the front frame head just like the VW one. Only problem is that the 911 M/C doesn't have threads so you will have to use nuts and bolts or heli-coil the M/C to give it some threads. Oh yea you will have to shorten the push rod or lenghen it I can't remember at the moment...
volkdent April 25th 2004 01:03
Thanks BOY! Have you used it yet? How's the pedal feel? Anyother options?
boygenius April 25th 2004 01:07
The chassis is still sitting on jackstands. The suspension and brakes should go on for the last time in the coming week sometime. So no I haven't used it yet. Alot of people have used the 944 M/C but I have not so I can't comment on how easy or hard the swap is.
Shadowbug April 26th 2004 01:28
i have a 944 MC to match my non turbo brakes. Bolts right up
volkdent April 26th 2004 12:42
Shadow, what is the feel like on the pedal?
Angelo Amato April 26th 2004 19:11
anyone used/looked into using....
a master cylinder from a Mk2/3 golf ?????
