-   -   are late 944 hubs the same as the early ones (https://www.germanlook.net/forums/showthread.php?t=4294)
pantswagen May 10th 2004 13:53
and do they fit a type 1 arm?
where can i buy - just the rear caliper mount
if this does fit together do i then need 86 only discs?
thank - you pleez :laugh:
Superman May 11th 2004 00:37
No, the hubs are not the same.
You'll just have to search around for the mounts (eBay, yards, etc.).
I'd have to know your set up to answer the last question.*
*if you refer to the rear turbo discs, then yes '86 only
