-   -   Ricola (https://www.germanlook.net/forums/showthread.php?t=4413)
beetle1303 June 1st 2004 23:04
Ricola
I was wondering which software did u use to design the wishbones...
At the moment im using solidworks2003 with FEA(finite element analysis) add-in. Did u kept the track width stock on ur design?
Thanx
beetle1303
Chris
ricola June 2nd 2004 04:22
ProEngineer and Ansys. Both more for double checking really as I am not going to extremes to save the odd gram in weight.
Geometry was the best I could get with the limitations of using a stock bug pan, I just did lots of research for the numbers!
Forgot to say: I made the suspension 10mm narrower per side to give a bit more room for big rims!
