911 Turbo rear end
Does anyone know the dimensions in question?
http://www.geocities.com/volkdent/Po...?1033809365820 Any info would be greatly appreciated. Jason:confused: |
I think you will have more luck on Porsche based boards.
This looks to me like a 993 rear end. Would be interesting to see it installed in a bug. Did you buy it for your project? If you are thinking about getting it into your bug you should look at a G50 tranny too since you have to cut up the rear of the pan anyways. Alex |
Where?
Any idea where an good active Porsche forum can be found?
Thanks. |
http://www.pelicanparts.com/index.htm
Also try Rennlist...do not have an URL for that but just make a search on google. Alex |
| All times are GMT -4. The time now is 15:43. |
