Kafer bar preload ?
How do you all set the preload on your kafer bars ?
pulling inwards towards the bar itself or pushing outwards away from the bar ? Thanks, Dan |
i went just barely to the pulling side of neutral. wanted to keep things tighter, but from what i understand you don't want a bunch of preload on them.
Thanks !
Dan |
Just installed mine and thought of that too. I figured since the engine wants to rotate righthand side, the right side wants to dive down bending the fork downwards (and it does, just blip the throttle and watch), so I preloaded the right side a bit by turning it inwards slightly.
Vice versa for the left hand side (when you stand behind your bug that is). Walter |
| All times are GMT -4. The time now is 03:08. |
