Type 181 flanges and frame forks
2 Attachment(s)
Hello Guys .
As im mounting my gearbox these days, i wander if any of you have a pic or info on how much space i need to make in my frame forks when using 181 flanges . Im also gonna use 944 ( 100 ) mm cv`s and axle shafts , rhino engine / gearbox mounts , and Berg front gearbox mount . So there shouldent be to much movement - Pic of what i have by now , Right and left side Regards Puma-alex |
As far as I know, if your pan is an original IRS pan, you don't have to do anything to the frame horns. They already have the necessary clearance for T181 flanges. Only the swing axle frame horns need to be clearanced when they are converted to IRS.
Thanks for the input mr Bruce ! My car is converted to irs , so thats part of the reason for the space issue .
Regards Puma-racing |
1cm to 1.5 cm
Alex,
I had the same problem when I converted my pan over to IRS. I moded the frame about 1 to 1.5 cm from the bottom of the tranny flange to the frame horn. I have the 72-901 tranny but I am using the 1969 901 tranny flanges cause they have the same bolt pattern as the stock VW. No matter what you type of flange you uce this should be enough room fot you. |
| All times are GMT -4. The time now is 01:47. |
