-   -   noobie on "Replacing stock mirror" (https://www.germanlook.net/forums/showthread.php?t=6304)
Aircoupe July 28th 2005 13:43
Hi All, first post. I recently got my first beetle, a 74 SB. Currently it has the stock drivers side rearview mirror. I'd like to replace it and add one to the passenger side with something a little more euro. I know there are lots of options, but does anyone sell sporty looking mirrors that will mount using the stock mounting hole? I am sure I could cover it up and drill new holes, but if I could avoid new holes I'd like too. Thanks!
Steve C July 28th 2005 19:08
I used local Ford mirrors from the 1970s, they had a leg which bolted to the Ford door, I cut this off and glassed it in, then I used the attaching arm from a stock mirror, cut the mirror off, drilled & tapped the end and bolted it trough the mirrors side. This is what they looked like on my old car. I take pictures of the arms if you need them.
http://www.clubvw.org.au/images/scaero_pw.jpg
Aircoupe July 28th 2005 20:35
Looks good....
Those look good Steve, I hadn't considered cutting the mounts off and reusing, it's something to think about. I also turned up some mirrors from RACETECH, looks like they mount with a single bolt similiar to the VW. I'll have to look closer at them too.
--Mitch
