911 alternator
Hi!
I have a 911 alternator with a 12 blade fan.Do not know the year of the car it came from, probably a late 993. Will like to know if someone had any experience with them, and or know how to wire them? Thanks Onix :idea: |
I have not wired a 993 alt. If you can find a wiring diagram for the donor car you should be able to trace the conections. Remember that if the car you are intalling it in has a voltage regulator, you must remove and bridge it first(you can find diagrams for this on the net. Search for VW alternator coversion).
Thanks for the reply!
My car already have the internal voltage regulator conversion done. The 911 alternator have in the back multiple conections but I think I know the important ones. B+ for the battery D+ for the dash light W I think for the ground Also had a terminal wich is marked only as +, not know where it conct it, but anyway I only have 3 cables for conection(above ones) Any sugestions? Thanks Onix :idea: |
| All times are GMT -4. The time now is 03:11. |
