carbs
what kind of dual carbs can i run on a budget im thinking of dual kads
Depends on your engine combo and budget. Kadrons and Weber 40IDF are more than adequate for a smaller displacement driver and can be found at reasonable prices.
it is a pretty good engine 94 pistions 044 race heads fk-8 can 72mm crank all that power and no way to make it go
A set of reworked Kads from AJ Simms will work, thoughy you would be further ahead with dual 44IDFs, 48IDFs/IDAs or 45 Dells. Add at least and 1 5/8" header (no boxes) to improve the flow and it should move plenty... ;)
ok that is what i was thinking
i think 1 5/8" is too much, better 1 1/2"
| All times are GMT -4. The time now is 21:03. |
