-   -   Turbocharging the VW engine (https://www.germanlook.net/forums/showthread.php?t=667)
BigPhattyVW November 12th 2002 15:23
Hello all from the Nordic Empress
I've been reading last months VW Trends and I am now really thinking about using that Kit on my engine. My question is can you use this turbo with electronic points. Its probably a stupid question but im just not sure on how you would be able to adjust the electronic points to the desired spot that VW Trends tells you to.
Thanks for you info
Clint
Oliver Knuf November 14th 2002 06:19
You mean a Compufire or an Ignitor module? Adjusting the points to a special point is not senseful, you mean the iginition timing, that is done by rotating the distributor! :-)
