-   -   Racecar parts for sale (https://www.germanlook.net/forums/showthread.php?t=7603)
jimby June 13th 2006 14:53
sparco seats sold
Digital Dash DD2Pro BRAND NEW BOXED £700
www.etbinstruments.com
http://www.etbinstruments.com/Images..._final_rgb.gif
http://www.etbinstruments.com/Images...al_rgb_72d.gif
Datalogger & Display System
With sensors, software and wiring harnesses included, the DigiDash2 - PRO offers a comprehensive package for the serious racer, track day driver or road user. The system comprises a separate Datalogger box and CANbus Display module (Pictured). Track mapping and video overlay come as standard within the package.
Function Summary
* Speed (mph / km/h selectable) (Maximum of 250mph or 400 Km/h)
* RPM (up to 25,000)
* Engaged Gear (calculation based)
* Water Temperature (in ºC or ºF)
* Oil Temperature (in ºC or ºF)
* Oil Pressure (in PSI or BAR)
* Auxiliary Pressure (fuel or boost)
* Fuel Level (% Remaining in Tank)
* Battery Voltage
* 2 axis G-sensor
* Race/Track day lap timer with up to 32 split times
* Elapsed race timer
* Programmable Shift Lights (3 Modes of Operation)
* Datalogger (17.3Mb)
* Selectable Sample Rate for Recording Data (10-20Hz)
* Brake System Usage logging
* Programmable Warning Alarms
* Maximum (Peak) Value Hold memory on all parameters
* Odometer (total & trip counter)
* Acceleration / Deceleration timer
* Engine Hour Counter
* Trip Distance Timer
* Built-in SVA Compliant Warning Lights
* BHP calculator
Technical Specifications
* Operating Voltage - 8-16v
* Max Power Consumption 400mA
* Dimensions:
Datalogger Box - 120mm x 110mm x 36mmDisplay - 160.4mm x 89.8mm x 28mm
* Weight - 600g
* Ingress Protection Rating - IP54
2.25L AFFF fire system £70 NEW but ive cut to length the fluid lines.
http://www.driftworks.com/catalog/im...herPlumbed.jpg
1 Gallon Aluminium foam filled fuel tank, USED sight gauge £20
IRS Gearbox, john maher racing built, cogbox serviced, quaiffe ATB diff, short ratios, new 3.88r+p all the fancy bits was jay aldreds race gearbox, he had it serviced when he finished with it £1400
Type 4 fitment eurorace 3 stage dry sump oil pump, new. £620
jim
07815 288850 :)
hillingdon, middlesex, england UK
jimby June 13th 2006 14:55
edited sold
foxdivfour June 18th 2006 16:20
How much work is required to get the dd2pro set up in a bug?
lazylongboarder June 18th 2006 19:39
How much for shipping to orem, ut, 84097 usa. Thanks
jimby June 19th 2006 06:42
you would have to install the two bits of hardware, wire them in and fit the sensors. it comes with all the parts to do this. its a full kit. you would need a computer to load the software for the downloading of the data. :)
jimby June 19th 2006 06:43
which part are you interested in, everything?
lazylongboarder June 19th 2006 14:26
Sorry, just the seats. Are they cosmetically in good condition besides the sub-belt hole? Pics? Thanks a lot.
Russell
the apprentice June 27th 2006 08:45
Interested in the seats too if they're still available - can I join the queue?
Any more pics available?
cheers, Phil
jimby June 29th 2006 14:13
Russell
sorry, unable to find a cardboard box big enough for the seats.
the apprentice June 29th 2006 19:18
Jimby, I take it that this does mean they are still available? If so, I'm interested...will collect if need be. Can I have some contact details please?
