type 4 1700cc engine
comes with a 210 flywheel and clutch
-it looks like it has a plate in it for type 1 shaft support pistons and barrels rings all look good -domed high comp -chambers in heads and the valves don't tho!! has short early j tubes -i cut the tower off havn't scooped it down tho has a bit of float can throw in a 901 fan 'ring' still has the early small threaded rockers -off -story is i went to get a 091 box, and had to buy the engine - which turned out to have fresh heads and seems rebuilt -new pump -push rod tubes etc -but its a vanagon head lump -and also i dont need the 210, as i'm 091 -and i have a complete fan unit, so -the 1700cc can go £200 quid cheap!!!!!!!!! collection only tho -london 0774 858 2044 -please don't expect too much -will swap for a pair of 40's with inlets? -give you 48mm inlets??? |
| All times are GMT -4. The time now is 04:00. |
