WTB 4 x 55 lb Bosch style fuel injectors
Does anybody want to split a set of 8 55 lb fuel injectors with me ? I need a set of 4 but EBay et al have sets of 8 for about $400 USD.
I only need 4 so looking for someone to split a set with ... I'd be looking to buy in the next month. Thanks Sandeep |
why 55lbs?
With the TD04 @ 16psi manifold pressure, duty cycle was 91% @ 5400 rpm with 40lb injectors.
The new heads should allow me to rev to 6500 rpm @ 18 psi manifold pressure ... and a VF39 turbo from a '05 STI just showed up at my door :eek: The STI also uses 55lb injectors ... ;) Sandeep |
Let me see what i need for teh split. I'll let you know.
I found a site with some good prices for a set of 4
57lb injectors High Z and flow matched, parts diagrams too. http://www.racetronix.com/3172FM.html Sandeep |
| All times are GMT -4. The time now is 05:00. |
