wiring required for 944 rev counter
can anyone help? :rolleyes:
cheers, Angelo |
One more thing...the tach from the '84 that I'm using is wired up as follows pin 4 GND
pin 5 +12 pin 6 coil - Pin's 1-3 and H+, Hg not used There you go, I tested it on my 914 and it works properly http://www.germanlook.com/Forums/sho...ght=944+wiring :) |
on the back of my 944 rev counter i have three pins: +12, 1, -. +12 is ign live. 1 is coil negative. - is earth.
rev counter wiring
help still needed.
The Fasty is now ALIVE and running :) i tried above wiring that i stated but rev counter does not work. got hold of the 944 wiring diagram off pelican parts but still cannot work it out. 1303R yours sounds the easiest ! is that an early 944 one then ??? to be honest, bought the rev counter used, i do not know if the rev counter works, but do they fail ?? cheers, Angelo |
the one i have came out early dash type 944 and has a pointy glass cover, 924's of same age have same type to.
| All times are GMT -4. The time now is 05:31. |
