5 speed
I need to start thinking about a 5 speed trans, but I have no clue where to start.
I've read about Porsche transmissions, Bus transmissions, Berg 5 speeds, Rancho Transmissions, you name it. So, in your opinion, what is the best (and most economical) way to go ? The trans should be able to live in front of a 165HP Subaru motor. No 5K clutchdrops, but it should be able to take a decent pounding.... Enlighten me ! :laugh: Rob |
Porsche trans of course IMO. By the time you build-up a T1 tranny with Berg 5 speed kit, and add super diff and the other goodies. A (used) stock 901, 914, or 915 is about the same price. Going 5 speed is not really econo, compared to a built T1 4 speed with right gearing.
If you go with the Porsche 901, I can help you install it :D
Sandeep |
Hey Sandeep,
How much did you spend on the whole setup ? Thanks, Rob. |
$800 for the gearbox ... thats it. The 901 is the original gearbox for the T4 I have so no issues with flywheel clutch.
Sandeep |
hey Rob I hate to Jump in on your Thread but what's really the Differest between the 901 and 915 Both 5 speed
I'm in the Same Stage thanks Chris. |
| All times are GMT -4. The time now is 02:16. |
