porsche bits
s4 calipers -£125
2.7 boxster -299mm disc £150 one 996 rear £65 944 front hubs calipers two pair of rear £125 -iron ones one 944 front hub £30 spindles -944 all years £25 944 master -brake £15 944 turbo -or 928 23/20 master -£55 fluid jar £45 servo £5 pair used 944 front discs 1986 £10 pair of 996 rear disc -used £25 one new 964 disc £55 swap any of the above for some 322mm by 32mm - by 80mm high discs -996 turbo2 928 gts -or maybe some 993 -2 piece jobbies items are in london - all sold as seen -0774 858 2044 |
jkn
hello i search four calipers two front and two rear but it's for a bus with T4 of 180 HP
which advised me you? Regards Pascal |
| All times are GMT -4. The time now is 04:42. |
