-   -   Nuts and Bolts (https://www.germanlook.net/forums/showthread.php?t=8665)
Rob May 24th 2007 16:57
Nuts and Bolts
Where do you guys go to get bolts and screws etc ?
I need some generic 6mm or 8mm bolts and nuts to fasten various things, and I'd like to get a large qty that will last me for a while.
Any hints / tips ?
Rob.
gonebuggy May 24th 2007 18:25
try your local industrial supply store,
or if you want quantities of 25, 50, 100 etc try "Fastenal" or "brafasco"
Cheers,
Steve C May 24th 2007 21:02
I'm not sure about where you are but I often buy them on EBay.
Bug@5speed(US) May 24th 2007 23:03
Also wurth, sells fasteners..
At least this way you know they are automotive grade..
petevw May 24th 2007 23:52
Rob, got mine from Fabory Metrican in Miss.
big daddy May 27th 2007 07:14
Nuts and Bolts
Rona or Home Depot sells metric high grade down to stainless stell fasteners.;)
55OVLRAG June 7th 2007 07:53
Metric Fastners
:righton: Try Bolts Plus at Torbram and Derry in Mississauga
Found that they have the best selection as well as having stainless
http://www.boltsplus.ca/mississauga.html
As well as Horton Hot Rod parts in Milton
www.horton.on.ca
