-   -   strengthing rear shock mounts (https://www.germanlook.net/forums/showthread.php?t=8859)
split_trix August 9th 2007 15:50
Has anyone tried to reinforce the lower rear shock mounts on an 944 alloy trailing arm ?
Maybe by welding on support from the bolt back to the arm ? almost like semi boxing the arm....
any ideas
chris
notch11 August 16th 2007 14:10
for what purpose? 944's can run rear coilovers no problem, and a 944 is heavier than any type 1 or type 3
Simon August 22nd 2007 07:30
It will hold, don't be afraid.
Several companies, including KW did very torough testing of the rear coilover setup without torsion bars and all tests passed.
