-   -   Biggest brakes in 16" Fuchs?? (https://www.germanlook.net/forums/showthread.php?t=8971)
vdubfund September 22nd 2007 05:08
Does anyone know the biggest brake setup that will fit inside 16"fuches
(6s and 7s) with out spacer?? Or slight spacing.
I know 944 N/As will work with boxter monos. But can I get 996 calipers and discs inside them?
Also my bug is a short axle `64. How is the fitment of the 7inch fuchs in the rear. Will I need spacer. At first I will be running 944N/As all round, but if I could fit turbo discs, I would like to go that route eventually. Uwe for MBT in Germany thinks the 996 set won`t work in fuchs. Would need to go to Boxter 16s at least.
Any info would be much appreciated. I have yet to get all my parts together to mock things up!
cheers
pantswagen September 26th 2007 08:50
the biggest stock porshe disc would be the 964 298mm on the front
on the rear if you use 944 hubs and discs -71mm offset ones
-the spoke will hit the caliper, you need at least 7mm
-so 10mm spacer on the rear i think
note on the front, 175 45 16 bridge stone potenza's are available
-if you can get them!!
ps i reckon you'd get a 310mm disc in, but then the boxster 2.5/7 calipers would be too small
-the 3.2 boxster '2' would work on a 310mm - 28mm thick disc
ALTHOUGH they run on a 318mm
DORIGTT September 26th 2007 16:12
Can the 16x6 911 fronts be used over the 944 calipers if a spacer is used to move the wheel away from the caliper a bit or is the diameter too great to fit inside the wheel?
vdubfund September 26th 2007 21:00
Thanks partswagen!
From what I can see on some Porsche website , maybe I can fit a 930 setup in stock 16" 911 fuchs, (304mm by 32mm front,and something like a 310mm by 28mm rear(stock 930 rear) Not to sure on the calipers as of yet. I`d like to use 996 calipers if possible.
Yes I can get those tires ! I live in Japan! I can get any low pro tire. Bridgestone ,Yokos, Pirelli they are all made for the Japanese market.
Thanks for the info. If you have any pics I`d love to see them.
Cheers
Dean
pantswagen September 26th 2007 21:37
http://img.photobucket.com/albums/v2...56738~original
this disc is 320mm
-the caliper is the boxster 's'
the disc ic mercedes on a bay hub
-it dont fit in this style 16inch wheel
http://img.photobucket.com/albums/v2...56874~original
with a 20mm sapcer it might
-i have definately fitted a 16 inch front fuch on a 944 rear, -i think the stock calipers are fine, with the 20mm spacer removed -bay front studs fitted
, but i then fitted 90-91 2 pot 964 rearr calipers, and i needed a spacer of 7mm - i cut the stock 944 spacer down - remember to cut the spigot in the rear
