Momo Install Help Needed
I am installing a Momo steering wheel and hub adapter on my 1971 Super. Has anyone done this? How did you wire up the horn?
i got one in mine
horn connection is same as all other wheels boss has a copper contact at the base and a wire goes from it upto the horn button horn button grounds out on the boss itself |
How did you attach it? Did you add a clip or connector or solder it? Don't mean to sound dumb, though I probably am. I just want to make sure I don't run into problems later.
Thanks |
Progress!
1 Attachment(s)
I figured it out that I had to remove the ring from the back side of the original steering wheel! Now it is installed!
| All times are GMT -4. The time now is 18:50. |
