selling my 1971 Super
Im selling my 1971 super pics on here in the gallery and on my site www.ecbug.com . Im asking $7000
New 1914 cc with less than 100 miles on it, Rancho pro street tranny also with less than 100 miles on it, and here is a list of the other parts: http://bellsouthpwp.net/c/i/civicfan...lowered003.jpg Body Modification 1302 S emblem on rear deck lid from Chris Percival Added pop out windows Aluminum running boards Blacked out Chrome Carbon Fiber gravel guards by Carbon Joe Rear spoiler Euro front apron Passenger side mirror Electronics Modification 6x9 2 ways by Kenwood CD player by Kenwood Engine Modification (1914cc) 009 by BOSCH New dual oil pressure relief case Forged counterweighted crank Blue Coil by BOSCH Engle 110 cam and cam gear Mahle Pistons and barrels w/heavy duty snap rings High rev springs and heavy duty retainers New lifters and steel pushrods 40 x 35.5 racing heads Solid rocker shafts w/swivel feet adjusters Forged chromoly eight doweled lightened flywheel ( 12lbs) Cool tin Balanced and Blueprinted Header w/ Single Quiet Pack by EMPI Magnetic Drain plug by EMPI Remote oil filter Dual 40/44mm hpmx Sump cover and deep sump by SCAT Traction bar by Low Budget Interior Modification Tachometer by Vee Oil pressure gauge by VDO Oil temp gauge by VDO Voltage gauge by VDO Shift light by Summit Racing Pro 90 full interior w/ seats by Scat Lighting Modification Amber fog lights Early turn signals w/clear lenses Fog light indicator in gauge H4 headlights Smoked tail lights Suspension Modification 3/4 Sway bar Rear by Topline 7/8 Sway bar Front by Topline Adjust-A-Struts by EMPI Caster fix bushing from Topline Flip it kit from Topline Lowered 1 notch in the rear Sport+ Tapered springs by CIP1 Strut tower brace by Topline Front 2 pot disc brakes Rear disc brakes Tires Modification 195 65 15 Transmission Modification Rancho pro street Transaxle Trigger shifter by EMPI Urethane shift coupler by Bugpack Wheels Modification 5.5 8 spoke black Also and extra running 1600 dp and stock tranny. If interested I also have a car hauler trailer (flat bed w/hydraulic lift) for $1500 only used once. |
| All times are GMT -4. The time now is 18:02. |
