I'm installing a couple gauges in my 1970 Beetle, and while I was messing around with the fusebox, I decided that a late-model type fuse box (with the blade-type fuses) would be much nicer.
Has anybody done this before ?
I did a bit of 'research' at the local Canadian Tire
, and it seems that the modern fuses do not come in 8 and 16 Amps.
Could I replace them with a lower amperage ? Or would they blow out all the time ?
Don't want to go with a much higher amperage, because I am not a fan of burning Beetles
Any hints, tips or wisecracks ?
Rob.
