View Single Post
Old July 3rd 2004, 02:05
vwpride73's Avatar
vwpride73 vwpride73 is offline
Forget the rotary, they might make some hp but they lack low end grunt. And the reason say a 10 second N/A type-1 engine is a pain to drive is because to make that kind of hp the need a super high lift cam, monster carbs, giant exhaust, and the heads ( Superflow and such). Now the down side of all of those parts, you sacrifice low end with the carbs, exhaust and the cam. The problem with the cam is that it doesn't "come on" until say 3500-4000 rpm. Now with these after market high-po heads they dont have the cooling fins like say a stock 041 head. Type-1 are mainly a peaky and violent engine compared to a type-4. What do you want from an engine? What is going to be it's purpose? And I think turbo-charging a type-1 or type-4 would be your best bet, but if you lack experience do your homework(books and other online material). The great thing about the turbo is to make more power you dont have to increase the size of the engine, up the compression, or anything else like you would with a N/A engine. A turbo is a torque mutiplier. Turbo = More Torque = More Fun.
'73 1302/1303
My car - http://www.cardomain.com/memberpage/320620
