View Single Post
Old August 9th 2004, 14:31
Axle will be a shortened stock MkIII version. Eventually I'm thinking O2M six speed, then I'll need custom axles. I'm using Porsche Boxter linkage for the shifter, it still has some kinks to get worked out. For the extra space, can you say "trunk!" or Boot if your from over the pond. Some space will be taken up by the exhaust, but I'll have quite a bit left over. Kataplun, click on Volkdent in the corner then look at volkdents homepage, then 1.8tconversion.
