What kind of wheel clearance do you have front and rear?
What is the offset and tire size used on the Boxster wheel?
Has wheel movement been hindered in any way?
It appears from the pictures that there isn't alot of room between the rear tires and the fenders...how much rubbing is there (notice I didn't ask if there was rubbing, only how much
If you used narrowed rear trailing arms, would it improve the clearance on the outboard side of the tire while still maintaining clearance on the inside edge?
Nice looking Ghia!
